주요 콘텐츠로 건너뛰기
Osmo Mobile Trigger Button Replacement
필요한 것
  1. Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: 1 단계, 이미지 2개 중 1개 Osmo Mobile Trigger Button Replacement, Osmo Mobile Handle Disassembly: 1 단계, 이미지 2개 중 2개
    • Remove gimbal from base handle by loosening round plate found at the top of the handle.
  2. Osmo Mobile Trigger Button Replacement: 2 단계, 이미지 2개 중 1개 Osmo Mobile Trigger Button Replacement: 2 단계, 이미지 2개 중 2개
    • Use Phillips #00 screwdriver to remove the three screws found on the gimbal stabilizer to detach handle from gimbal.
    • Carefully detach handle from gimbal and disconnect the cable that connects the two.
  3. Osmo Mobile Trigger Button Replacement: 3 단계, 이미지 1개 중 1개
    • Locate the hex screws found at the top base of the handle, and unscrew using the 1.5mm hex screwdriver.
  4. Osmo Mobile Trigger Button Replacement: 4 단계, 이미지 2개 중 1개 Osmo Mobile Trigger Button Replacement: 4 단계, 이미지 2개 중 2개
    • Remove joystick by gently pulling away from handle
  5. Osmo Mobile Trigger Button Replacement: 5 단계, 이미지 3개 중 1개 Osmo Mobile Trigger Button Replacement: 5 단계, 이미지 3개 중 2개 Osmo Mobile Trigger Button Replacement: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • Remove the quick release PCBA by locating the connecting wires and release the ribbon cable with tweezers.
    • Use the spudger to pry open and remove the face plate, starting at the back of the handle.
  6. Osmo Mobile Trigger Button Replacement: 6 단계, 이미지 3개 중 1개 Osmo Mobile Trigger Button Replacement: 6 단계, 이미지 3개 중 2개 Osmo Mobile Trigger Button Replacement: 6 단계, 이미지 3개 중 3개
    • Locate four screws directly on top of handle.
    • Unscrew the silver, bottom two screws, that are closest to the face plate using the 00 screwdriver.
    • Unscrew the black, top two screws, located furthest from the face plate, using the 0 screwdriver.
    • Remove the remaining two screws found on the front of the faceplate.
    • Remove the rest of the face plate shell.
  7. Osmo Mobile Trigger Button Replacement, Charging Port: 7 단계, 이미지 1개 중 1개
    • Remove the top left screw on the joystick panel with Phillips #00 screwdriver.
    • Lift faceplate holding joystick module.
  8. Osmo Mobile Trigger Button Replacement: 8 단계, 이미지 1개 중 1개
    • Remove the bottom right screw on the joystick panel with the #00 Phillips screwdriver.
  9. Osmo Mobile Trigger Button Replacement: 9 단계, 이미지 1개 중 1개
    • Hold down the larger of the two ribbon cables, and pull on circuit board with a constant and careful down and out motion.
  10. Osmo Mobile Trigger Button Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the two screws from the green charging module and the two screws on the grey plate and remove from handle.
    • Replace charging module.
  11. Osmo Mobile Trigger Button Replacement, Trigger Button: 11 단계, 이미지 2개 중 1개 Osmo Mobile Trigger Button Replacement, Trigger Button: 11 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Use the tweezers to push outward on the backside of the trigger button hinges.
    • Pop out trigger button.
  12. Osmo Mobile Trigger Button Replacement: 12 단계, 이미지 1개 중 1개
    • Use the tweezers to remove the underlying button that contacts with the trigger button, and replace.
결론
작성자
4다른 기여자 명과 함께
William Tyler Wills
회원 가입일: 09/28/17
429 평판
안내서 4개를 작성함
USF Tampa, Team S2-G1, Nance Fall 2017 USF Tampa, Team S2-G1, Nance Fall 2017 회원
USFT-NANCE-F17S2G1
4 회원들
안내서 12개를 작성함
1가이드 댓글
How I can fix the USB port, it went inside the handle?
Juan Carlos Beltran - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 8
지난 30일: 35
전체 시간: 2,960
