주요 콘텐츠로 건너뛰기
Oster 16-Speed Blender Blades Replacement
  1. Oster 16-Speed Blender Blades Replacement, Container: 1 단계, 이미지 1/2 Oster 16-Speed Blender Blades Replacement, Container: 1 단계, 이미지 2/2
    • First, remove the blender container from the Blender Base, by grabbing the handle and lifting up.
  2. Oster 16-Speed Blender Blades Replacement: 2 단계, 이미지 1/2 Oster 16-Speed Blender Blades Replacement: 2 단계, 이미지 2/2
    • Next, remove the lid from the Blender Container.
  3. Oster 16-Speed Blender Blades Replacement: 3 단계, 이미지 1/2 Oster 16-Speed Blender Blades Replacement: 3 단계, 이미지 2/2
    • Flip the container on its side so that the bottom faces you.
    • Now rotate the bottom counter-clockwise to remove it from the container.
  4. Oster 16-Speed Blender Blades Replacement: 4 단계, 이미지 1/2 Oster 16-Speed Blender Blades Replacement: 4 단계, 이미지 2/2
    • Now you will see the bottom of the blender blades once the bottom piece is removed
    • Carefully remove the blender blades from the container seeing as they are very sharp and can cut you.
  5. Oster 16-Speed Blender Blades Replacement: 5 단계, 이미지 1/1
    • Now your container is separated.
  6. Oster 16-Speed Blender Blades Replacement, Blades: 6 단계, 이미지 1/1
    • Flip the blender container on its side so that the bottom faces you.
    • Now, you can insert the new set of blades into the container.
    • Be careful when handling the blender blades as they are sharp and can cut you.
결론
Dana
회원 가입일: 04/14/14
779 평판
안내서 5개 작성하였습니다
Cal Poly, Team 12-37, Maness Spring 2014 Cal Poly, Team 12-37, Maness Spring 2014 회원
CPSU-MANESS-S14S12G37
4 회원들
안내서 7개 작성하였습니다
댓글 한 개
This is misleading, Step 1 shows a chrome ring on the bottom of the Blender Container, but all the other steps don’t show that.
This makes it very difficult to grip the black piece on the bottom of the Blender Container.
spbeggs - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 14
전체 시간: 6,357
