주요 콘텐츠로 건너뛰기
Oster 6329 Outer Shell Removal
필요한 것
  1. Oster 6329 Outer Shell Removal, Outer Shell Removal: 1 단계, 이미지 1/2 Oster 6329 Outer Shell Removal, Outer Shell Removal: 1 단계, 이미지 2/2
    • Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
  2. Oster 6329 Outer Shell Removal: 2 단계, 이미지 1/1
    • Push the plastic push-down handle down and pull the plastic handle straight from metal arm.
  3. Oster 6329 Outer Shell Removal: 3 단계, 이미지 1/1
    • Loosen the outer metal shell from the plastic base by holding the plastic base while pulling up on the metal shell.
    • Only lift the outer shell a little so as not to disconnect the cables that connect the circuit board.
  4. Oster 6329 Outer Shell Removal: 4 단계, 이미지 1/2 Oster 6329 Outer Shell Removal: 4 단계, 이미지 2/2
    • Disconnect the cable clips from the circuit board using the tweezers to free the outer metal shell from the plastic base.
  5. Oster 6329 Outer Shell Removal: 5 단계, 이미지 1/2 Oster 6329 Outer Shell Removal: 5 단계, 이미지 2/2
    • Lift the top outer metal shell.
    • Carefully lift the outer metal shell at an angle so as not to damage the components in the front of the toaster.
결론
Isaac Williams
회원 가입일: 01/24/14
225 평판
안내서 2개 작성하였습니다
Cal Poly, Team 13-15, Regan Winter 2014 Cal Poly, Team 13-15, Regan Winter 2014 회원
CPSU-REGAN-W14S13G15
5 회원들
안내서 6개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 22
전체 시간: 1,905
