이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
소개
Removing the power cord is straightforward, but it does require soldering.
필요한 것
Using the Phillips-head #2 screwdriver, unscrew the three 1cm Phillips-head screws on the plastic base of the toaster to separate the outer metal shell from the plastic base.
Using a flat-head screwdriver, pry the power cord from the base of the toaster.
거의 끝나갑니다!
결론
