주요 콘텐츠로 건너뛰기
Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement
필요한 것
  1. Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement, Blades: 1 단계, 이미지 1/2 Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement, Blades: 1 단계, 이미지 2/2
    • Flip the pitcher over while holding the handle.
  2. Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 2 단계, 이미지 1/2 Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 2 단계, 이미지 2/2
    • Hold the handle of the pitcher and twist the base loose.
  3. Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 3 단계, 이미지 1/1
    • Remove the base from the pitcher.
  4. Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 4 단계, 이미지 1/1
    • Remove the blades and the blender seal from the pitcher.
    • Be careful when handling the blender blades because they are sharp and can cut you.
  5. Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 5 단계, 이미지 1/2 Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 5 단계, 이미지 2/2
    • Remove the blender seal from the blades.
  6. Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 6 단계, 이미지 1/2 Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 6 단계, 이미지 2/2
    • Place the blender seal back onto the pitcher.
  7. Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 7 단계, 이미지 1/2 Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 7 단계, 이미지 2/2
    • Place the new blade on the seal of the pitcher.
  8. Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 8 단계, 이미지 1/3 Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 8 단계, 이미지 2/3 Oster 8-Speed Blender BLSTMG-B00-33A Blades Replacement: 8 단계, 이미지 3/3
    • Place the base back onto the pitcher and twist it into place.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Nathan Didier
회원 가입일: 09/14/20
157 평판
안내서 1개 작성함
York University, Team S2-G4, Melo-Thaiss Fall 2020 York University, Team S2-G4, Melo-Thaiss Fall 2020 회원
YORK-MELO-THAISS-F20S2G4
1 회원
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 17
전체 시간: 339
