주요 콘텐츠로 건너뛰기
Oster BLSTSS-PZO Blades & Seal Ring Replacement
  1. Oster BLSTSS-PZO Blades & Seal Ring Replacement, Blades & Seal Ring: 1 단계, 이미지 1/1
    • First, remove the blender container from the blender base by grabbing the container and lifting it up.
  2. Oster BLSTSS-PZO Blades & Seal Ring Replacement: 2 단계, 이미지 1/1
    • Flip the container, where the bottom faces you.
    • Then, rotate the bottom piece counter-clockwise to remove it from the container.
  3. Oster BLSTSS-PZO Blades & Seal Ring Replacement: 3 단계, 이미지 1/1
    • Carefully remove the bottom piece from the container.
    • Be careful while removing the blades from the container, as seeing they are very sharp and can hurt you.
  4. Oster BLSTSS-PZO Blades & Seal Ring Replacement: 4 단계, 이미지 1/1
    • Now, your container and blades are separated.
결론
Farhan
회원 가입일: 09/20/17
104 평판
안내서 1개 작성함
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 472
