주요 콘텐츠로 건너뛰기
Oster BLSTSS-PZO Gear Shaft Replacement
필요한 것
  1. Oster BLSTSS-PZO Gear Shaft Replacement, Circuitboard: 1 단계, 이미지 1/1
    • Use the prying tools to open the four plastic screw holes on the bottom of the blender.
  2. Oster BLSTSS-PZO Gear Shaft Replacement: 2 단계, 이미지 1/1
    • Use the Phillips #1 Screwdriver to unscrew the four 16 mm screws and remove the plastic bottom.
  3. Oster BLSTSS-PZO Gear Shaft Replacement: 3 단계, 이미지 1/1
    • Gently remove the circuit board.
  4. Oster BLSTSS-PZO Gear Shaft Replacement: 4 단계, 이미지 1/2 Oster BLSTSS-PZO Gear Shaft Replacement: 4 단계, 이미지 2/2
    • Use the spudger to detach the black wire from the circuit board.
    • Repeat for yellow wire.
  5. Oster BLSTSS-PZO Gear Shaft Replacement: 5 단계, 이미지 1/3 Oster BLSTSS-PZO Gear Shaft Replacement: 5 단계, 이미지 2/3 Oster BLSTSS-PZO Gear Shaft Replacement: 5 단계, 이미지 3/3
    • Use the Phillips #1 to remove the four 8mm screws.
    • Use the medal spudger to detach the circuit board from the buttons.
    • Gently pull and release circuit board from buttons.
  6. Oster BLSTSS-PZO Gear Shaft Replacement, Gear Shaft: 6 단계, 이미지 1/3 Oster BLSTSS-PZO Gear Shaft Replacement, Gear Shaft: 6 단계, 이미지 2/3 Oster BLSTSS-PZO Gear Shaft Replacement, Gear Shaft: 6 단계, 이미지 3/3
    • Remove the screw on top of the fan with the 4mm socket stock wrench.
    • Remove the fan and washer.
  7. Oster BLSTSS-PZO Gear Shaft Replacement: 7 단계, 이미지 1/3 Oster BLSTSS-PZO Gear Shaft Replacement: 7 단계, 이미지 2/3 Oster BLSTSS-PZO Gear Shaft Replacement: 7 단계, 이미지 3/3
    • Remove the four screws with the 4mm socket stock wrench.
    • Remove gear shaft.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Tristian Cruz
회원 가입일: 09/20/17
263 평판
안내서 2개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 27
전체 시간: 710
