주요 콘텐츠로 건너뛰기
Oster Blend-N-Go My Blend Blender Bottle Replacement
  1. Oster Blend-N-Go My Blend Blender Bottle Replacement, Blender Bottle: 1 단계, 이미지 1/2 Oster Blend-N-Go My Blend Blender Bottle Replacement, Blender Bottle: 1 단계, 이미지 2/2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Blender Bottle Replacement: 2 단계, 이미지 1/3 Oster Blend-N-Go My Blend Blender Bottle Replacement: 2 단계, 이미지 2/3 Oster Blend-N-Go My Blend Blender Bottle Replacement: 2 단계, 이미지 3/3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Paul Long
회원 가입일: 08/27/15
710 평판
안내서 4개 작성하였습니다
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 5
전체 시간: 747
