주요 콘텐츠로 건너뛰기
Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement
  1. Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement, Blender Bottle: 1 단계, 이미지 2개 중 1개 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement, Blender Bottle: 1 단계, 이미지 2개 중 2개
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: 2 단계, 이미지 3개 중 1개 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: 2 단계, 이미지 3개 중 2개 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: 2 단계, 이미지 3개 중 3개
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement, Drinking Lid Assembly: 3 단계, 이미지 1개 중 1개
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: 4 단계, 이미지 3개 중 1개 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: 4 단계, 이미지 3개 중 2개 Oster Blend-N-Go My Blend Drinking Lid Assembly Replacement: 4 단계, 이미지 3개 중 3개
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Walter Hernandez
회원 가입일: 09/01/15
274 평판
안내서 1개를 작성함
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G6
3 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 4
지난 30일: 13
전체 시간: 487
