주요 콘텐츠로 건너뛰기
Oster Blend-N-Go My Blend Drinking Lid Seal Replacement
필요한 것
  1. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: 1 단계, 이미지 1/2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Blender Bottle: 1 단계, 이미지 2/2
    • Grip the blender base with one hand and blender bottle with the other hand.
    • Rotate the blender bottle a quarter turn counterclockwise .
    • Lift the blender bottle out of the blender base. The blade assembly should still be attached to the blender bottle.
  2. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 2 단계, 이미지 1/3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 2 단계, 이미지 2/3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 2 단계, 이미지 3/3
    • Grip the blade assembly with one hand and blender bottle with the other hand.
    • Rotate the blade assembly counterclockwise until it is completely unscrewed from the blender bottle.
    • Lift the blender bottle to separate it from the blade assembly.
  3. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Assembly: 3 단계, 이미지 1/1
    • After removing the blade assembly from the blender bottle, ensure that your drinking lid assembly has its seal placed in the seal bed.
  4. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 4 단계, 이미지 1/3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 4 단계, 이미지 2/3 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 4 단계, 이미지 3/3
    • Grab the blender bottle with one hand and the drinking lid assembly with the other.
    • Place the drinking lid assembly onto the blender bottle and twist it clockwise until it is tight around the blender bottle.
  5. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement, Drinking Lid Seal: 5 단계, 이미지 1/1
    • After separating the drinking lid assembly from the blender bottle, position the plastic opening tool on either side of the seal in the drinking lid assembly.
    • Wedge the tool between seal and seal seat wall.
  6. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 6 단계, 이미지 1/2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 6 단계, 이미지 2/2
    • Gently pry the seal up while lifting seal out of the seal seat.
  7. Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 7 단계, 이미지 1/2 Oster Blend-N-Go My Blend Drinking Lid Seal Replacement: 7 단계, 이미지 2/2
    • Press new seal into seal seat with finger.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Paul Long
회원 가입일: 08/27/15
710 평판
안내서 4개 작성하였습니다
USF Tampa, Team 12-6, Blackwell Fall 2015 USF Tampa, Team 12-6, Blackwell Fall 2015 회원
USFT-BLACKWELL-F15S12G6
3 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 11
전체 시간: 840
