주요 콘텐츠로 건너뛰기
Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement
필요한 것
  1. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Removal: 1 단계, 이미지 1/1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 2 단계, 이미지 1/3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 2 단계, 이미지 2/3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 2 단계, 이미지 3/3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 3 단계, 이미지 1/2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 3 단계, 이미지 2/2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 4 단계, 이미지 1/2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 4 단계, 이미지 2/2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
  5. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: 5 단계, 이미지 1/3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: 5 단계, 이미지 2/3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement, Top Panel Buttons: 5 단계, 이미지 3/3
    • Disconnect microcontroller and top lining.
    • Ground yourself prior to disconnecting in order to avoid harming the inner electronics.
  6. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 6 단계, 이미지 1/2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 6 단계, 이미지 2/2
    • Remove the two 11mm Phillips #1 screws from the top cover.
  7. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 7 단계, 이미지 1/1
    • Use spudger to pop the control panel out.
  8. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 8 단계, 이미지 1/3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 8 단계, 이미지 2/3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 8 단계, 이미지 3/3
    • Remove the four 11mm Phillips #1 screws from the control panel.
  9. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 9 단계, 이미지 1/3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 9 단계, 이미지 2/3 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 9 단계, 이미지 3/3
    • Remove the two 11mm Phillips #1 screws from the button panel.
    • Flip the screen assembly over and remove the button panel.
  10. Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 10 단계, 이미지 1/2 Oster Expressbake CKSTBRTW20 Top Panel Buttons Replacement: 10 단계, 이미지 2/2
    • Remove and replace buttons as necessary.
결론
Megan Saunders
회원 가입일: 01/25/18
701 평판
안내서 5개 작성하였습니다
USF Tampa, Team S7-G5, Passmore Spring 2018 USF Tampa, Team S7-G5, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 5
전체 시간: 255
