주요 콘텐츠로 건너뛰기
Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement
필요한 것
  1. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement, Top Panel Removal: 1 단계, 이미지 1/1
    • Remove the bread pan.
  2. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: 2 단계, 이미지 1/3 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: 2 단계, 이미지 2/3 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: 2 단계, 이미지 3/3
    • Remove the eight 22mm Phillips #1 screws from the grey lining.
    • Remove the grey liner.
  3. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: 3 단계, 이미지 1/2 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: 3 단계, 이미지 2/2
    • Remove the two 11mm Phillips #1 screws from the back of the device.
  4. Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: 4 단계, 이미지 1/2 Oster Expressbake CKSTBRTW20 Top Panel Removal Replacement: 4 단계, 이미지 2/2
    • Pop off the top case using a spudger.
    • Keep the spudger away from the control panel.
    • Be aware of wires connecting the microcontroller to the panel when removing the top lining.
결론
Megan Saunders
회원 가입일: 01/25/18
701 평판
안내서 5개 작성하였습니다
USF Tampa, Team S7-G5, Passmore Spring 2018 USF Tampa, Team S7-G5, Passmore Spring 2018 회원
USFT-PASSMORE-S18S7G5
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 1
7일 전: 3
30일 전: 7
전체 시간: 491
