주요 콘텐츠로 건너뛰기
Outdoor Faucet Head Replacement
필요한 것
  1. Outdoor Faucet Head Replacement, Outdoor Faucet Head: 1 단계, 이미지 1개 중 1개
    • Check the location of the water leakage, and turn off the water to that area.
    • Drain the water in the pipeline after it is determined, so as to avoid a large amount of water flowing out during the repair process.
  2. Outdoor Faucet Head Replacement: 2 단계, 이미지 1개 중 1개
    • Use a wrench to remove the leaking faucet by turning it counter-clockwise.
    • Be careful not to damage the water pipe.
  3. Outdoor Faucet Head Replacement: 3 단계, 이미지 2개 중 1개 Outdoor Faucet Head Replacement: 3 단계, 이미지 2개 중 2개
    • Use PFTE tape to wrap the faucet mouth.
    • The purpose of this step is to prevent the faucet from still leaking after installation.
  4. Outdoor Faucet Head Replacement: 4 단계, 이미지 2개 중 1개 Outdoor Faucet Head Replacement: 4 단계, 이미지 2개 중 2개
    • Install the replaced new faucet and confirm whether it is tightened.
  5. Outdoor Faucet Head Replacement: 5 단계, 이미지 1개 중 1개
    • Turn on the faucet and monitor whether the faucet is leaking. If not, the repair is over.
결론
There are no sharp objects used in the whole process, but you need to be careful that there may be places where the water pipes may be easily scratched.
작성자
1다른 기여자 명과 함께
Zelong jiao
회원 가입일: 09/19/21
268 평판
안내서 1개를 작성함
댓글 0개
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 4
지난 30일: 17
전체 시간: 659
