주요 콘텐츠로 건너뛰기
Outer Shell Disassembly
필요한 것
  1. Outer Shell Disassembly, Outer Shell Disassembly: 1 단계, 이미지 1/2 Outer Shell Disassembly, Outer Shell Disassembly: 1 단계, 이미지 2/2
    • Unplug the device from any energy sources.
    • Lift the top cover of the scanner.
    • Use a plastic opening tool to remove the plastic frame surrounding the glass.
  2. Outer Shell Disassembly: 2 단계, 이미지 1/1
    • Carefully pull the frame away from the glass.
    • If it doesn't remove easily, use the iFixit Opening Tool again to pry stuck sections.
  3. Outer Shell Disassembly: 3 단계, 이미지 1/1
    • Use a T10 screwdriver to unscrew the two screws that fasten the frame to the printer hood.
  4. Outer Shell Disassembly: 4 단계, 이미지 1/2 Outer Shell Disassembly: 4 단계, 이미지 2/2
    • Put your finger behind the panel with the power button.
    • Then, pull the piece outwards.
  5. Outer Shell Disassembly: 5 단계, 이미지 1/2 Outer Shell Disassembly: 5 단계, 이미지 2/2
    • Unscrew the screw inside the power button panel space.
    • Then, unscrew the screw that is across the printer slider.
  6. Outer Shell Disassembly: 6 단계, 이미지 1/1
    • Pull the white circuit board outwards which is located under the small screen.
    • Unplug the small ribbon cable from the circuit board.
    • Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
    • Unplug the small ribbon cable from the circuit board. Be careful when you unplug the ribbon cable not to use too much force. Using too much force may damage or rip the cable.
  7. Outer Shell Disassembly: 8 단계, 이미지 1/2 Outer Shell Disassembly: 8 단계, 이미지 2/2
    • Pull the memory card reader's circuit board out.
    • Detach the white wiring connector from the back of the circuit board.
    • You may need to use a finger nail or a plastic opening tool to detach the white wiring connector from the circuit board.
  8. Outer Shell Disassembly: 9 단계, 이미지 1/2 Outer Shell Disassembly: 9 단계, 이미지 2/2
    • Put your finger behind the small screen.
    • Then, pull it up.
    • Do not hesitate to use force to remove the TouchSmart panel.
    • Disconnect the ribbon cable from the small screen.
  9. Outer Shell Disassembly: 10 단계, 이미지 1/1
    • Pull the printer hood upward.
결론
To reassemble, simply follow the steps in reverse order.
다른 8명이 해당 안내서를 완성하였습니다.
Renee Lamb
회원 가입일: 09/26/12
235 평판
안내서 3개 작성하였습니다
Cal Poly, Team 2-11, Propen Fall 2012 Cal Poly, Team 2-11, Propen Fall 2012 회원
CPSU-PROPEN-F12S2G11
4 회원들
안내서 6개 작성하였습니다
댓글 한 개
Excellent helpful easy to follow instructions. Thanks.
In step 7, removal of the Touch Pad, I was not able to locate the release clip. Feeling around, what I thought was the latch was a ribbon cable that I distorted but didn't destroy. The top came off without the Touch Pad removal. Once the top was off, I located a latch on the back right of the Touch Pad, but once released, it didn't help to free up the Touch Pad. I couldn't get the Touch Pad off.
Ken - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 15
전체 시간: 9,659
