주요 콘텐츠로 건너뛰기
Ozeri Pronto ZK14-S Panel Removal Replacement
단지 전제 조건
이 안내서는 다른 가이드의 선행 작업으로 사용하기 위한 것입니다. 그 자체로는 불완전합니다.
필요한 것
  1. Ozeri Pronto ZK14-S  Panel Removal  Replacement, Panel Removal: 1 단계, 이미지 1/2 Ozeri Pronto ZK14-S  Panel Removal  Replacement, Panel Removal: 1 단계, 이미지 2/2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 2 단계, 이미지 1/1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 3 단계, 이미지 1/1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 4 단계, 이미지 1/2 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 4 단계, 이미지 2/2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 5 단계, 이미지 1/2 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 5 단계, 이미지 2/2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 6 단계, 이미지 1/1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 7 단계, 이미지 1/1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 8 단계, 이미지 1/1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S  Panel Removal  Replacement: 9 단계, 이미지 1/2 Ozeri Pronto ZK14-S  Panel Removal  Replacement: 9 단계, 이미지 2/2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
결론
AshleyKreisel
회원 가입일: 10/01/15
101 평판
안내서 1개 작성함
USF Tampa, Team 1-4, Leahy Fall 2015 USF Tampa, Team 1-4, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 0
30일 전: 7
전체 시간: 61
