소개
This guide explains how to expose the LCD screen of the Ozeri Pronto ZK14-S. The detachment of the LCD motherboard is necessary to reveal the actual screen.
필요한 것
이 단계에 사용된 도구:Flathead 3/32" or 2.5 mm Screwdriver$5.49
Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screw on the back of the center LCD motherboard.
다른 3명이 해당 안내서를 완성하였습니다.
댓글 한 개
I had a similar model, it was different to open but the LCD was showing all 8's, I just reset the same LCD and it worked like new.
