주요 콘텐츠로 건너뛰기
Ozeri Pronto ZK14-S LCD Replacement
필요한 것
  1. Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: 1 단계, 이미지 1/2 Ozeri Pronto ZK14-S LCD Replacement, Panel Removal: 1 단계, 이미지 2/2
    • Twist the plastic plate slowly to the left to pull it away.
  2. Ozeri Pronto ZK14-S LCD Replacement: 2 단계, 이미지 1/1
    • Lift up the sticker at the bottom where the “Ozeri” logo is to reveal a screw.
    • The sticker does not need to be completely removed.
  3. Ozeri Pronto ZK14-S LCD Replacement: 3 단계, 이미지 1/1
    • Using a 2.0 Flathead screwdriver, remove the 9.50 mm Phillips head screw under the sticker.
  4. Ozeri Pronto ZK14-S LCD Replacement: 4 단계, 이미지 1/2 Ozeri Pronto ZK14-S LCD Replacement: 4 단계, 이미지 2/2
    • Using a 2.0 Flathead screwdriver, remove the two 18.76 mm Phillips head screws in the plate stand.
  5. Ozeri Pronto ZK14-S LCD Replacement: 5 단계, 이미지 1/2 Ozeri Pronto ZK14-S LCD Replacement: 5 단계, 이미지 2/2
    • Using a 2.0 Flathead screwdriver, remove the 9.44 mm Phillips head screw on the edge opposite to the LCD screen.
  6. Ozeri Pronto ZK14-S LCD Replacement: 6 단계, 이미지 1/1
    • Turn the device over so the back panel is facing up.
  7. Ozeri Pronto ZK14-S LCD Replacement: 7 단계, 이미지 1/1
    • Using the iFixit opening tool, pry off the two rubber stubs on the right side and the two rubber stubs on the left side of the bottom of the device.
  8. Ozeri Pronto ZK14-S LCD Replacement: 8 단계, 이미지 1/1
    • Using a 2.0 Flathead screwdriver, remove the four 9.46 mm Phillips head screws that were under the rubber stubs.
  9. Ozeri Pronto ZK14-S LCD Replacement: 9 단계, 이미지 1/2 Ozeri Pronto ZK14-S LCD Replacement: 9 단계, 이미지 2/2
    • Pry apart the two panels to separate them from each other.
    • Flip the device over so the LCD is facing up. Flip the front panel over on its side.
    • Be careful when separating the panels to avoid damaging the wires they are connected by.
  10. Ozeri Pronto ZK14-S LCD Replacement, LCD: 10 단계, 이미지 1/2 Ozeri Pronto ZK14-S LCD Replacement, LCD: 10 단계, 이미지 2/2
    이 단계에 사용된 도구:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    구매
    • Using the 2.0 Flathead screwdriver, remove the three 7.20 mm screw on the back of the center LCD motherboard.
  11. Ozeri Pronto ZK14-S LCD Replacement: 11 단계, 이미지 1/3 Ozeri Pronto ZK14-S LCD Replacement: 11 단계, 이미지 2/3 Ozeri Pronto ZK14-S LCD Replacement: 11 단계, 이미지 3/3
    • Stand the center motherboard up to expose the LCD screen
    • Be careful when standing up the LCD motherboard to avoid damaging the wires it is connected to.
    • Remove the LCD screen.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Oneika White
회원 가입일: 10/01/15
709 평판
안내서 4개 작성하였습니다
USF Tampa, Team 1-4, Leahy Fall 2015 USF Tampa, Team 1-4, Leahy Fall 2015 회원
USFT-LEAHY-F15S1G4
4 회원들
안내서 5개 작성하였습니다
댓글 한 개
I had a similar model, it was different to open but the LCD was showing all 8's, I just reset the same LCD and it worked like new.
Dennis Lima - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 3
30일 전: 8
전체 시간: 554
