주요 콘텐츠로 건너뛰기
PDP Afterglow Wired Xbox 360 Controller Button Replacement
필요한 것
  1. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: 1 단계, 이미지 1/2 PDP Afterglow Wired Xbox 360 Controller Button Replacement, Case: 1 단계, 이미지 2/2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 3 단계, 이미지 1/1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Button Replacement, Button: 4 단계, 이미지 1/1
    • Remove the rubber button covers from the A, B, X, and Y buttons.
  5. PDP Afterglow Wired Xbox 360 Controller Button Replacement: 5 단계, 이미지 1/2 PDP Afterglow Wired Xbox 360 Controller Button Replacement: 5 단계, 이미지 2/2
    • Push up on the buttons from the front and pull them out from the back.
결론
다른 3명이 해당 안내서를 완성하였습니다.
Joi Officer
회원 가입일: 09/17/15
283 평판
안내서 2개 작성하였습니다
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G1
4 회원들
안내서 5개 작성하였습니다
댓글 3개
What about removing the Dpad? i really need help.
Elijah Douglas - 답글
I’m sorry but, I have to say that the reassembly process is harder than simply ‘follow the instructions in reverse’; if you try and place the half with the buttons, the buttons fall out or end up misaligned ; and if you use the other half, the rubber covers and the tumblers will fall out.
Again, this guild comes off a little too simple, there’s more to it.
Christopher Mali-Martinez - 답글
the circuit board comes off the other half. You can stack them very easily. You're simply incorrect.
Tyler Anderson -
댓글 쓰기
조회 통계:
24 시간 전: 2
7일 전: 5
30일 전: 28
전체 시간: 4,950
