주요 콘텐츠로 건너뛰기
PDP Afterglow Wired Xbox 360 Controller Cable Replacement
필요한 것
  1. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: 1 단계, 이미지 1/2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Case: 1 단계, 이미지 2/2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 3 단계, 이미지 1/1
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: 4 단계, 이미지 1/2 PDP Afterglow Wired Xbox 360 Controller Cable Replacement, Cable: 4 단계, 이미지 2/2
    • Remove the logic board by lifting up on the logic board and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 5 단계, 이미지 1/1
    • The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
  6. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 6 단계, 이미지 1/1
    • The soldering iron is very hot and can harm you or the device if used incorrectly.
    • Desolder the four pins.
  7. PDP Afterglow Wired Xbox 360 Controller Cable Replacement: 7 단계, 이미지 1/1
    • Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
결론
다른 5명이 해당 안내서를 완성하였습니다.
Jayson Norcross
회원 가입일: 09/17/15
283 평판
안내서 1개 작성함
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G1
4 회원들
안내서 5개 작성하였습니다
댓글 4개
where can I find a replacement cable to perform this precedure with?
Aaron English - 답글
yes!! i would like to know too.. i have been searching for long time for that cable
sokratis162 -
Android cable
Wayne -
U can use a old Android cable
Wayne - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 10
30일 전: 49
전체 시간: 6,872
