부품
지정된 부품이 없습니다.
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
Remove the logic board by lifting up on the logic board and pulling out.
The cable connects to the logic board with a white connector. Above the right joystick, there are four solder pins labeled GND, VCC, DM, and DP.
Using your new cable, solder the white connector to the logic board. Be sure to have the cables facing towards the inside of the logic board.
다른 5명이 해당 안내서를 완성하였습니다.
댓글 4개
where can I find a replacement cable to perform this precedure with?
yes!! i would like to know too.. i have been searching for long time for that cable
Android cable
Wayne -
