주요 콘텐츠로 건너뛰기
PDP Afterglow Wired Xbox 360 Controller Case Replacement
필요한 것
  1. PDP Afterglow Wired Xbox 360 Controller Case Replacement, Case: 1 단계, 이미지 1/2 PDP Afterglow Wired Xbox 360 Controller Case Replacement, Case: 1 단계, 이미지 2/2
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Case Replacement: 2 단계, 이미지 1/1
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Case Replacement: 3 단계, 이미지 1/1
    • Remove the top cover from the bottom and place next to each other.
결론
Aaron
회원 가입일: 09/14/15
103 평판
안내서 1개 작성함
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G1
4 회원들
안내서 5개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 7
전체 시간: 1,296
