주요 콘텐츠로 건너뛰기
PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement
필요한 것
  1. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement, Joysticks: 1 단계, 이미지 1/1
    • Remove the two 11 mm screws from the back of the controller using a Phillips #0 screwdriver.
    • Remove the five 8 mm screws from the back of the controller using a Phillips #0 screwdriver.
  2. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 2 단계, 이미지 1/1
    • Remove the back cover from the controller and set it aside.
  3. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 3 단계, 이미지 1/1
    • Remove the circuit board from the front casing.
    • Be cautious of disconnecting the vibration motors which are attached by thin wires.
  4. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 4 단계, 이미지 1/3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 4 단계, 이미지 2/3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 4 단계, 이미지 3/3
    • Wiggle and pull the joystick until it comes off of the circuit board.
  5. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 5 단계, 이미지 1/2 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 5 단계, 이미지 2/2
    • Place the new joystick into position and press until the joystick makes a click.
  6. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 6 단계, 이미지 1/1
    • Place the circuit board and vibration motors back into the front casing.
  7. PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 7 단계, 이미지 1/3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 7 단계, 이미지 2/3 PDP Afterglow Wired Xbox 360 Controller Joysticks Replacement: 7 단계, 이미지 3/3
    • Place the back cover into position.
    • Reinsert the two 11 mm screws into the back of the controller using a Phillips #0 screwdriver.
    • Reinsert the five 8 mm screws into the back of the controller using a Phillips #0 screwdriver.
결승점
다른 한 분이 해당 안내서를 완성하였습니다.
Dillon Earl Jones
회원 가입일: 09/28/21
149 평판
안내서 1개 작성함
University of North Texas, Team 2-5, Raign Fall 2021 University of North Texas, Team 2-5, Raign Fall 2021 회원
UNT-RAIGN-F21S2G5
2 회원들
안내서 1개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 24
30일 전: 73
전체 시간: 2,642
