주요 콘텐츠로 건너뛰기
PDP Afterglow Wired Xbox 360 Controller LEDs Replacement
필요한 것
  1. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: 1 단계, 이미지 2개 중 1개 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: 4 단계, 이미지 2개 중 1개 PDP Afterglow Wired Xbox 360 Controller LEDs Replacement, LEDs: 4 단계, 이미지 2개 중 2개
    • Remove the logic board from the controller casing by lifting up and pulling out.
  5. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: 5 단계, 이미지 1개 중 1개
    • Locate the LED (s) that needs to be replaced.
    • Once the LED has been located, flip the logic board to the other side and locate the pins associated with the LED that needs to be replaced.
  6. PDP Afterglow Wired Xbox 360 Controller LEDs Replacement: 6 단계, 이미지 1개 중 1개
    • Desolder the LED from the logic board.
    • The soldering iron is very hot and can harm you or the device if used improperly.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Joi Officer
회원 가입일: 09/17/15
298 평판
안내서 2개를 작성함
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G1
4 회원들
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 5
지난 30일: 25
전체 시간: 2,256
