주요 콘텐츠로 건너뛰기
PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement
필요한 것
  1. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Case: 1 단계, 이미지 2개 중 1개 PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Case: 1 단계, 이미지 2개 중 2개
    • Loosen the seven 11 mm Phillips #0 screws located on the back of the controller.
  2. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: 2 단계, 이미지 1개 중 1개
    • Using a plastic opening tool, pry the back cover from the front.
    • The covers should separate without needing a plastic opening tool, but in some cases you may need to use it.
  3. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: 3 단계, 이미지 1개 중 1개
    • Remove the top cover from the bottom and place next to each other.
  4. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Vibration Motors: 4 단계, 이미지 2개 중 1개 PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement, Vibration Motors: 4 단계, 이미지 2개 중 2개
    • Lift the Logic Board and remove the rumble motors from the base of the controller.
  5. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: 5 단계, 이미지 1개 중 1개
    • The rumble motors are located in the bottom right and left hand corners of the controller.
    • Find where the power (red) wire and ground (black) wire are connected to the logic board. The power (red) wire should be on the left while the black (ground) wire is on the right.
  6. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: 6 단계, 이미지 1개 중 1개
    • The soldering iron is very hot and can harm you or the device if used improperly.
    • Take the soldering iron after it has been heated up and place it where the ground (black) wire is connected to the logic board.
    • Let it heat up and remove some of the solder with the solder vacuum.
    • Do the same for the power (red) wire.
  7. PDP Afterglow Wired Xbox 360 Controller Vibration Motors Replacement: 7 단계, 이미지 1개 중 1개
    • Now take the new rumble motor and place the power (red) wire on the right hole where the (+) sign is.
    • Take some solder and seal the hole so that the solder is completely covering the (+) hole.
    • Do the same for the ground wire.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
4다른 기여자 명과 함께
Austin Miller
회원 가입일: 09/18/15
197 평판
안내서 1개를 작성함
IUPUI, Team 3-1, Harley Fall 2015 IUPUI, Team 3-1, Harley Fall 2015 회원
IUPUI-HARLEY-F15S3G1
4 회원들
안내서 5개를 작성함
1가이드 댓글
Where can I purchase just the rumble motors? I'd like to try adding rumble to a PDP Rock Candy controller, which is essentially the same controller as the AfterGlow but in a neon colored shell and no LED lighting. I don't know if they'll actually work but it would be a fun project.
Josh Koontz - 답글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 7
지난 30일: 29
전체 시간: 3,131
