주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PDP Rematch Action Buttons Replacement
필요한 것
  1. PDP Rematch Action Buttons Replacement, Faceplate: 1 단계, 이미지 2개 중 1개 PDP Rematch Action Buttons Replacement, Faceplate: 1 단계, 이미지 2개 중 2개
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Action Buttons Replacement: 2 단계, 이미지 2개 중 1개 PDP Rematch Action Buttons Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Action Buttons Replacement: 3 단계, 이미지 2개 중 1개 PDP Rematch Action Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Gently lift off the hard cover with your hand; it should not need much force.
  4. PDP Rematch Action Buttons Replacement, Action Buttons: 4 단계, 이미지 1개 중 1개
    • Optional: Use a cotton pad or cotton swab with some alcohol to gently clean any debris.
    • These buttons are not connected to the device and will fall out, so be careful.
  5. PDP Rematch Action Buttons Replacement: 5 단계, 이미지 3개 중 1개 PDP Rematch Action Buttons Replacement: 5 단계, 이미지 3개 중 2개 PDP Rematch Action Buttons Replacement: 5 단계, 이미지 3개 중 3개
    • Carefully remove the buttons from the device and set them aside.
    • From here, you can do a deeper clean, or replace them.
    • The clear plate will not sit right or click into place if the buttons are not aligned straight.
결론
작성자
3다른 기여자 명과 함께
Katie Barnes
회원 가입일: 01/17/24
85 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 9
지난 30일: 51
전체 시간: 793
