소개
The back shell of your PDP Rematch Advanced should be replaced if it's damaged or if you want to swap it out for a different color shell. If you need to replace the back shell, take out the motherboard with this guide.
필요한 것
Orient the controller so the back side is facing you.
Use a Phillips #000 screwdriver to remove the seven 9 mm screws that secure the back shell.
거의 끝나갑니다!
결론
