주요 콘텐츠로 건너뛰기
PDP Rematch Joystick Cover Replacement
필요한 것
  1. PDP Rematch Joystick Cover Replacement, Faceplate: 1 단계, 이미지 2개 중 1개 PDP Rematch Joystick Cover Replacement, Faceplate: 1 단계, 이미지 2개 중 2개
    • Grip one side of the controller firmly.
    • Insert an opening pick into the crease between the faceplate and the body of the controller.
    • Once the pick creates a gap in the crease, gently insert another pick into a different section of the crease.
    • Carefully move the picks along the controller's crease line until you hear a popping sound.
    • Gently lift off the faceplate by hand.
  2. PDP Rematch Joystick Cover Replacement: 2 단계, 이미지 2개 중 1개 PDP Rematch Joystick Cover Replacement: 2 단계, 이미지 2개 중 2개
    • Remove the 8 mm screws from the hard cover using a JIS #00 screwdriver.
    • Since the screws have been removed, avoid shaking or moving your controller too much to prevent other buttons from falling out.
  3. PDP Rematch Joystick Cover Replacement: 3 단계, 이미지 2개 중 1개 PDP Rematch Joystick Cover Replacement: 3 단계, 이미지 2개 중 2개
    • Gently lift off the hard cover with your hand; it should not need much force.
  4. PDP Rematch Joystick Cover Replacement, Joystick Cover: 4 단계, 이미지 1개 중 1개
    • The action buttons and silicone pad are loose and may fall out of the controller.
  5. PDP Rematch Joystick Cover Replacement: 5 단계, 이미지 2개 중 1개 PDP Rematch Joystick Cover Replacement: 5 단계, 이미지 2개 중 2개
    • Gently rotate or twist the joystick(s) you want to replace.
    • Apply some force and pull upward towards you.
    • You will know it is released when you hear a popping sound.
    • Place your new joystick and push it downwards; you will hear a popping sound again.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Amina Begum
회원 가입일: 01/15/24
282 평판
안내서 2개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 16
지난 30일: 57
전체 시간: 682
