주요 콘텐츠로 건너뛰기
PDP Victrix Gambit Prime Wired Tournament Controller Joystick Cover Replacement
필요한 것
  1. PDP Victrix Gambit Prime Wired Tournament Controller Joystick Cover Replacement, Joystick Cover: 1 단계, 이미지 1개 중 1개
    • Insert an opening tool in the gap between the rear and front case.
    • Pry around the perimeter until the front case releases.
    • Remove the front case.
    • If your device has a circular Directional Pad, remove it first to access the faceplate.
  2. PDP Victrix Gambit Prime Wired Tournament Controller Joystick Cover Replacement: 2 단계, 이미지 1개 중 1개
    • Firmly grasp the joystick cover and pull it straight up and off of the controller.
  3. PDP Victrix Gambit Prime Wired Tournament Controller Joystick Cover Replacement: 3 단계, 이미지 1개 중 1개
    • Align the new joystick with the controller's socket; press down until it clicks into place.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
1다른 기여자 명과 함께
Tessa Baldwin
회원 가입일: 08/28/24
653 평판
안내서 5개를 작성함
1가이드 댓글
Helpful and clear instructions given by the Author. Although an opening tool is definitely overkill for removing the faceplate as it's held on by a few magnets and requires little effort. If the faceplate doesn't come off easily it's probably because you need to remove the circular D-Pad (which the Author mentions in Step 1 - "i")
Nate Allen - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 7
전체 시간: 311
