주요 콘텐츠로 건너뛰기
PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement
필요한 것
  1. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement, Outer Casing: 1 단계, 이미지 1개 중 1개
    • Insert an opening tool in the gap between the rear and front case.
    • Pry around the perimeter until the front case releases.
    • Remove the front case.
  2. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: 2 단계, 이미지 1개 중 1개
    • Remove all seven 9 mm Phillips #000 screws securing the midframe.
    • Remove the midframe.
  3. PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: 3 단계, 이미지 2개 중 1개 PDP Victrix Gambit Prime Wired Tournament Controller Outer Case Replacement: 3 단계, 이미지 2개 중 2개
    • Optional: With a pair of tweezers, carefully wipe down the device.
    • It is recommended to use electrical disinfectant wipes or a microfiber towel to clean any excess debris.
결론
After you have thoroughly cleaned the device, follow these steps in reverse order to reassemble the device.
작성자
4다른 기여자 명과 함께
Tessa Baldwin
회원 가입일: 08/28/24
653 평판
안내서 5개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 1
지난 30일: 7
전체 시간: 147
