주요 콘텐츠로 건너뛰기
POLAR CADENCE SENSOR BLUETOOTH® SMART Battery replacement
  1. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, The Sensor: 1 단계, 이미지 1개 중 1개
    • Removed Cadence Senosor from frame
  2. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Cutting open the Sensor: 2 단계, 이미지 3개 중 1개 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Cutting open the Sensor: 2 단계, 이미지 3개 중 2개 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Cutting open the Sensor: 2 단계, 이미지 3개 중 3개
    • Either use hacksaw or Dremel to cut open downside of the sensor. Use the carve of the body for guidance.
  3. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Behind the circuit board lies the truth: 3 단계, 이미지 3개 중 1개 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Behind the circuit board lies the truth: 3 단계, 이미지 3개 중 2개 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Behind the circuit board lies the truth: 3 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    • After cutting the downside, sensor can easily be opened. Remove circuit board with care not to break the pin. Remove copper clamp with tweezers.
  4. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement: 4 단계, 이미지 1개 중 1개
    • Replacing the battery
    • Move magnet close to diode. Flashing indicates successful replacement
  5. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Glueing it up: 6 단계, 이미지 2개 중 1개 POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement, Glueing it up: 6 단계, 이미지 2개 중 2개
    • Glue it up (maybe nicer than I did)
    • Second functional test with glued chasis
  6. POLAR CADENCE SENSOR BLUETOOTH® SMART  Battery replacement: 8 단계, 이미지 1개 중 1개
    • Bonus IC Identification:
    • Texas Instruments MSP430F5502 16-Bit Microcontroller w/ 24 KB Flash
    • Nordic Semiconductor nRF8001 Bluetooth Low-Energy Transceiver
결론
작성자
2다른 기여자 명과 함께
Milena Haiges
회원 가입일: 04/06/21
2,702 평판
안내서 3개를 작성함
2가이드 댓글
I used a razor blade in a box cutter knife (very carefully!) to gradually cut through the glue in the seam at the bottom of the device. It took many careful, small cuts to finally cut through so I could carefully pry the device open. After replacing the battery and testing it, I glued it back together with a crafting hot glue gun. This type of hot glue is waterproof, but you need to make sure there is no gap around the entire device seam. I was able to make a reasonable seal all around the device, and then I used a vice clamp to hold it together for drying. Next is outdoor testing.
Albert - 답글
Charging problems
Shakti Saa - 답글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 5
지난 30일: 20
전체 시간: 1,932
