주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PS Vita Slim Battery Replacement
필요한 것
  1. PS Vita Slim Battery  Replacement, Back Panel: 1 단계, 이미지 1개 중 1개
    • Please make sure the system is completely powered off and all SD storage cards are removed before starting the removal process
    • All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
    • There are four screws on the back of the device, remove them as shown.
  2. PS Vita Slim Battery  Replacement: 2 단계, 이미지 2개 중 1개 PS Vita Slim Battery  Replacement: 2 단계, 이미지 2개 중 2개
    • There are two screws on the bottom, near the charging port, remove them using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
    • Finally, remove the top screw under the dust cover using the J00 screwdriver on the 6.35mm screws from the iFixit pro toolkit.
  3. PS Vita Slim Battery  Replacement: 3 단계, 이미지 3개 중 1개 PS Vita Slim Battery  Replacement: 3 단계, 이미지 3개 중 2개 PS Vita Slim Battery  Replacement: 3 단계, 이미지 3개 중 3개
    • The next step will require the opening tool.
    • Please carefully separate the back from the front completely. You will need to disconnect the small ribbon cable on the inside before completely removing the back. Otherwise you may end up hurting the ribbons on the inside.
    • While separating the back, carefully pry all the way around the back. You will hear popping noises while going around and this is a good sign.
    • Upon removing the back panel you will need to slowly and carefully remove the ribbons connecting the hardware to access the needed parts to be repaired.
  4. PS Vita Slim Battery  Replacement: 4 단계, 이미지 1개 중 1개
    • Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
  5. PS Vita Slim Battery  Replacement, Battery: 5 단계, 이미지 3개 중 1개 PS Vita Slim Battery  Replacement, Battery: 5 단계, 이미지 3개 중 2개 PS Vita Slim Battery  Replacement, Battery: 5 단계, 이미지 3개 중 3개
    이 단계에 사용된 도구:
    Spudger
    $3.99
    • The battery should be very visible at this point in the guide.
    • Using the spudger, carefully pry the battery connector upwards out of the socket. Do not fully remove the battery yet.
    • Now using the tweezers, carefully remove the ribbon connecting the battery from the hardware.
    • The battery isn't held in by anything, so it can fall out of the case if turned upside down.
  6. PS Vita Slim Battery  Replacement: 6 단계, 이미지 1개 중 1개
    • Now the battery is removable and the process should be complete. You should be free to do what is needed.
결론
다른 12명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Daniel Woodard
회원 가입일: 08/22/17
3,208 평판
안내서 7개를 작성함
2가이드 댓글
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
Jack Wallis - 답글 공유
The touchpad cable isn't able to be re-attached if you do this so your vita just ends up becoming permanently crippled. DO NOT FOLLOW THIS GUIDE.
polocatfan - 답글 공유
댓글 쓰기
조회 통계:
지난 24시간: 39
지난 7일: 182
지난 30일: 790
전체 시간: 45,923
