소개
This guide's goal is to help the user to replace the battery of a PS Vita Slim if the battery is faulty or has some other kind of problem.
필요한 것
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
Once the ribbons have been removed, then the back is fully removed and you can access the hardware within.
Don’t forget to remove the battery at this point. The little corners of the connector that poke out a bit are there for you to pry the connector up. Be careful pulling the battery connector out by the wire, you could damage the wire where it is attached to the connector.
Using the spudger, carefully pry the battery connector upwards out of the socket. Do not fully remove the battery yet.
Now using the tweezers, carefully remove the ribbon connecting the battery from the hardware.
다른 10명이 해당 안내서를 완성하였습니다.
댓글 한 개
Whilst tearing down my PCH-2016 model PS Vita Slim I have noticed that there is also a screw in the cartridge area that needs to be removed to remove the back panel.
I actually broke a 32GB storage card because I didn’t remove it first before I open the chasis. Beware of this!!! REMOVE YOUR CARD FIRST!!!
Daniel Wang - 답글
