소개
Note::: taking apart your device may void the warranty on the device, please proceed with caution and consider having it sent in first if possible to be worked on by the company. This guides goal is to help you replace your motherboard if anything is currently wrong with it. As long as you take your time and you are careful you should be able to complete the replacement process with any problems.
필요한 것
All 6.35mm screws were removed using a J00 bit from the iFixit pro toolkit.
There are four screws on the back of the device, remove them as shown.
Remove the two screws that are holding the casing down. These will be 6.35 mm screws that are to be removed using the J00 bit from the iFixit pro toolkit.
Once the screws are removed, carefully lift the case out of the system.
다른 9명이 해당 안내서를 완성하였습니다.
댓글 한 개
bonjour ma ps vita slim
batterie changé et la console a du mal a demarré quand elle s'allume comme si c'est comme elle a pas de batterie se remet a zero et apres on lance un jeu elle s'éteint et quand elle redémarre remettre heure c'est quoi le probleme
merci
