주요 콘텐츠로 건너뛰기
이 안내서에는 최근 변경 사항이 더 있습니다. 최신 비검증 버전으로 전환하십시오.
PSP 1000 Buttons Replacement
필요한 것
  1. PSP 1000 Buttons Replacement, Battery: 1 단계, 이미지 1/1
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Buttons Replacement: 2 단계, 이미지 1/2 PSP 1000 Buttons Replacement: 2 단계, 이미지 2/2
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 Buttons Replacement: 3 단계, 이미지 1/2 PSP 1000 Buttons Replacement: 3 단계, 이미지 2/2
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 Buttons Replacement, Front Casing: 4 단계, 이미지 1/2 PSP 1000 Buttons Replacement, Front Casing: 4 단계, 이미지 2/2
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 Buttons Replacement: 5 단계, 이미지 1/1
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Buttons Replacement: 6 단계, 이미지 1/2 PSP 1000 Buttons Replacement: 6 단계, 이미지 2/2
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 Buttons Replacement, Buttons: 7 단계, 이미지 1/3 PSP 1000 Buttons Replacement, Buttons: 7 단계, 이미지 2/3 PSP 1000 Buttons Replacement, Buttons: 7 단계, 이미지 3/3
    • If the Arrow Buttons are not functioning properly, flip over the outer casing and locate the inside of the buttons, as shown
    • Carefully remove the black rubber backing off of the buttons.
    • Clean the inside of the rubber and the outside of the buttons with a cloth.
  8. PSP 1000 Buttons Replacement: 8 단계, 이미지 1/2 PSP 1000 Buttons Replacement: 8 단계, 이미지 2/2
    • If needed, replace the old buttons with a new set (which can be purchased from Sony or other electronics stores).
    • Carefully re-insert the buttons. This should not require excess force, as the buttons should fit if they are arranged correctly.
    • Gently re-apply the back rubber to the back of the buttons.
  9. PSP 1000 Buttons Replacement: 9 단계, 이미지 1/2 PSP 1000 Buttons Replacement: 9 단계, 이미지 2/2
    • If function buttons (x, square, circle, triangle) need to be replaced, find the corresponding black rubber backing on the inside of the casing.
    • Carefully remove the back rubber to expose the rear side of the buttons as shown. (This can be done using your hands.)
  10. PSP 1000 Buttons Replacement: 10 단계, 이미지 1/2 PSP 1000 Buttons Replacement: 10 단계, 이미지 2/2
    • Next, carefully clean the receiving end of the buttons on the motherboard (shown on picture) with a cloth.
    • If the buttons are clearly damaged, then they need to be replaced.
    • Add the new ones in the form, with the correct button order. (The correct button order has the Triangle on the top, Square on the right, Circle on the left, and X on the bottom).
    • Be very careful! The buttons only go in one way. If you have trouble fitting them in, rotate them in their given spots until they fit in easily. Do NOT force them. Forcing the buttons in may cause damage.
  11. PSP 1000 Buttons Replacement: 11 단계, 이미지 1/1
    • Once buttons are correctly replaced, the back rubbers are fit back onto the buttons, refer back to Replacing the Housing to reattach the casing.
결론
다른 32명이 해당 안내서를 완성하였습니다.
Henry Lee
회원 가입일: 01/14/10
794 평판
안내서 4개 작성하였습니다
Cal Poly, Team 5-6, Forte Winter 2010 Cal Poly, Team 5-6, Forte Winter 2010 회원
CPSU-FORTE-W10S5G6
5 회원들
안내서 22개 작성하였습니다
댓글 12개
It's a helpful guide,thx
Zero Knight - 답글
Great guide. I highly Recomend this to anyone that needs to replace their PSP buttons
unashamed45 - 답글
Otimo guia recomendo.
richardmosman - 답글
use magnetised screwdriver i had a normal one and it was a pain in the ass to put those tiny little bastards back
Nagy Dániel - 답글
Thank you this was a great guide
BLAISE of BASH - 답글
댓글 쓰기
조회 통계:
24 시간 전: 22
7일 전: 98
30일 전: 462
전체 시간: 82,333
