주요 콘텐츠로 건너뛰기
PSP 1000 LCD Screen Replacement
필요한 것
  1. PSP 1000 LCD Screen Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 LCD Screen Replacement: 2 단계, 이미지 2개 중 1개 PSP 1000 LCD Screen Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 LCD Screen Replacement: 3 단계, 이미지 2개 중 1개 PSP 1000 LCD Screen Replacement: 3 단계, 이미지 2개 중 2개
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 LCD Screen Replacement, Front Casing: 4 단계, 이미지 2개 중 1개 PSP 1000 LCD Screen Replacement, Front Casing: 4 단계, 이미지 2개 중 2개
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 LCD Screen Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 LCD Screen Replacement: 6 단계, 이미지 2개 중 1개 PSP 1000 LCD Screen Replacement: 6 단계, 이미지 2개 중 2개
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 LCD Screen Replacement, LCD Screen: 7 단계, 이미지 1개 중 1개
    • The Button Board, at the base of the LCD Screen, is held by two clips.
    • Pry these clips over the nubs using a PSP opening tool. This will release the clips.
    • The Button Board is still attatched to the PSP by a ribbon cable!
  8. PSP 1000 LCD Screen Replacement: 8 단계, 이미지 3개 중 1개 PSP 1000 LCD Screen Replacement: 8 단계, 이미지 3개 중 2개 PSP 1000 LCD Screen Replacement: 8 단계, 이미지 3개 중 3개
    • The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch.
  9. PSP 1000 LCD Screen Replacement: 9 단계, 이미지 2개 중 1개 PSP 1000 LCD Screen Replacement: 9 단계, 이미지 2개 중 2개
    • The LCD Screen is held by the LCD Frame with similar clips. Slide a thin tool between the clip and the screen and gently pry them apart while beginning to lift the screen.
  10. PSP 1000 LCD Screen Replacement: 10 단계, 이미지 1개 중 1개
    • The LCD screen is still attached with ribbon cables. Gently lift up the LCD screen so you do not break them.
  11. PSP 1000 LCD Screen Replacement: 11 단계, 이미지 3개 중 1개 PSP 1000 LCD Screen Replacement: 11 단계, 이미지 3개 중 2개 PSP 1000 LCD Screen Replacement: 11 단계, 이미지 3개 중 3개
    • The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
    • The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
    • Both of these latches are the black pieces.
    • Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
    • When reassembling - be careful which way you push the latches. The small one is very easy to break.
결승점
다른 77명이 해당 안내서를 완성하였습니다.
작성자
15다른 기여자 명과 함께
Henry Lee
회원 가입일: 01/14/10
866 평판
안내서 4개를 작성함
Cal Poly, Team 5-6, Forte Winter 2010 Cal Poly, Team 5-6, Forte Winter 2010 회원
CPSU-FORTE-W10S5G6
5 회원들
안내서 34개를 작성함
8가이드 댓글
I broke one of the laches....helppp!!!!
janet - 답글
This is not easy...I tore up the outer casing trying to do this. I better see money in the mail for this
Justin Autrey - 답글
My Sony PSP has just stop coming on
lil bao - 답글
People!! If you weren't gifted in screws and bolts, then bring your console to a repair shop. Seriously blaming this for your Dick Fingers?
janisfranckevics - 답글
댓글 쓰기
조회 통계:
지난 24시간: 24
지난 7일: 199
지난 30일: 801
전체 시간: 93,911
