주요 콘텐츠로 건너뛰기
PSP 1000 Speakers Replacement
필요한 것
  1. PSP 1000 Speakers Replacement, Battery: 1 단계, 이미지 1개 중 1개
    • Turn the PSP over so its back is facing you.
  2. PSP 1000 Speakers Replacement: 2 단계, 이미지 2개 중 1개 PSP 1000 Speakers Replacement: 2 단계, 이미지 2개 중 2개
    • Locate the battery casing button on the rear-left side of the PSP.
    • Press down the button and remove the battery cover.
  3. PSP 1000 Speakers Replacement: 3 단계, 이미지 2개 중 1개 PSP 1000 Speakers Replacement: 3 단계, 이미지 2개 중 2개
    • Using your finger, remove the battery upwards from the system as shown.
  4. PSP 1000 Speakers Replacement, Front Casing: 4 단계, 이미지 2개 중 1개 PSP 1000 Speakers Replacement, Front Casing: 4 단계, 이미지 2개 중 2개
    • Remove the four screws shown with a Phillips #00 screwdriver.
    • You will have to peel back the guarantee sticker to access the screw on the lower left.
  5. PSP 1000 Speakers Replacement: 5 단계, 이미지 1개 중 1개
    • Remove the screw from the bottom side of the PSP. Keep it separated from the rest of the screws.
    • Remove screws from back righthand side within the holes.
  6. PSP 1000 Speakers Replacement: 6 단계, 이미지 2개 중 1개 PSP 1000 Speakers Replacement: 6 단계, 이미지 2개 중 2개
    • Gently separate the outer plastic casing from the rest of the system as shown.
  7. PSP 1000 Speakers Replacement, LCD Screen: 7 단계, 이미지 1개 중 1개
    • The Button Board, at the base of the LCD Screen, is held by two clips.
    • Pry these clips over the nubs using a PSP opening tool. This will release the clips.
    • The Button Board is still attatched to the PSP by a ribbon cable!
  8. PSP 1000 Speakers Replacement: 8 단계, 이미지 3개 중 1개 PSP 1000 Speakers Replacement: 8 단계, 이미지 3개 중 2개 PSP 1000 Speakers Replacement: 8 단계, 이미지 3개 중 3개
    • The Button Board Ribbon Cable is held down with a latch. Lift the latch open, away from the ribbon cable.
    • Pull the cable away from the latch.
  9. PSP 1000 Speakers Replacement: 9 단계, 이미지 2개 중 1개 PSP 1000 Speakers Replacement: 9 단계, 이미지 2개 중 2개
    • The LCD Screen is held by the LCD Frame with similar clips. Slide a thin tool between the clip and the screen and gently pry them apart while beginning to lift the screen.
  10. PSP 1000 Speakers Replacement: 10 단계, 이미지 1개 중 1개
    • The LCD screen is still attached with ribbon cables. Gently lift up the LCD screen so you do not break them.
  11. PSP 1000 Speakers Replacement: 11 단계, 이미지 3개 중 1개 PSP 1000 Speakers Replacement: 11 단계, 이미지 3개 중 2개 PSP 1000 Speakers Replacement: 11 단계, 이미지 3개 중 3개
    • The thin Ribbon Cable opens from the opposite side in which the Ribbon Cable enters. Open up the latch towards the Ribbon Cable. The latch will pull up and release the ribbon cable. Put your tool behind the black part, then pry up the black piece of plastic.
    • The wide Ribbon Cable opens from the same side in which the Ribbon Cable attatches, and opens away from the cable.
    • Both of these latches are the black pieces.
    • Gently pull the ribbon cables away from the latches. The LCD screen can now be removed.
    • When reassembling - be careful which way you push the latches. The small one is very easy to break.
  12. PSP 1000 Speakers Replacement, Speakers: 12 단계, 이미지 1개 중 1개
    • Remove the screws on the top and bottom of the frame. Be sure to keep track of where you took each screw out of.
  13. PSP 1000 Speakers Replacement: 13 단계, 이미지 1개 중 1개
    • After the screws are removed, the bottom of the LCD frame will rise.
    • Open up the UMD Drive, and then slide the top of the LCD frame slightly to the right while pulling out.
  14. PSP 1000 Speakers Replacement: 14 단계, 이미지 1개 중 1개
    • The speakers will now be exposed.
  15. PSP 1000 Speakers Replacement: 15 단계, 이미지 2개 중 1개 PSP 1000 Speakers Replacement: 15 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • The speakers should slide out fairly easily; it may be helpful to use tweezers to begin prying them out.
  16. PSP 1000 Speakers Replacement: 16 단계, 이미지 3개 중 1개 PSP 1000 Speakers Replacement: 16 단계, 이미지 3개 중 2개 PSP 1000 Speakers Replacement: 16 단계, 이미지 3개 중 3개
    • Gently unplug the speakers from the socket. The speakers are completely detatched when they are unplugged from the logic board.
결론
다른 11명이 해당 안내서를 완성하였습니다.
작성자
6다른 기여자 명과 함께
Chris
회원 가입일: 01/14/10
2,090 평판
안내서 1개를 작성함
Cal Poly, Team 5-6, Forte Winter 2010 Cal Poly, Team 5-6, Forte Winter 2010 회원
CPSU-FORTE-W10S5G6
5 회원들
안내서 34개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 8
지난 7일: 40
지난 30일: 208
전체 시간: 27,893
