주요 콘텐츠로 건너뛰기
PSP 2000 Front Casing Replacement
필요한 것
  1. PSP 2000 Front Casing Replacement, Battery: 1 단계, 이미지 1/3 PSP 2000 Front Casing Replacement, Battery: 1 단계, 이미지 2/3 PSP 2000 Front Casing Replacement, Battery: 1 단계, 이미지 3/3
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Front Casing Replacement, Front Casing: 2 단계, 이미지 1/1
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Front Casing Replacement: 3 단계, 이미지 1/2 PSP 2000 Front Casing Replacement: 3 단계, 이미지 2/2
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Front Casing Replacement: 4 단계, 이미지 1/2 PSP 2000 Front Casing Replacement: 4 단계, 이미지 2/2
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
    Beware that some models of PSP 2000 (mine is a limited edition Crisis Core FF7 silver version, so I suppose it is related to it being a japanese PSP) have 2 minute TORX screws (T1? T2?) instead of the 2x 4mm Phillips pointed in orange around the USB port.
    Mighty Sashiman - 답글
  5. PSP 2000 Front Casing Replacement: 5 단계, 이미지 1/2 PSP 2000 Front Casing Replacement: 5 단계, 이미지 2/2
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
결론
다른 13명이 해당 안내서를 완성하였습니다.
pepe32290
회원 가입일: 10/19/09
1,573 평판
안내서 4개 작성하였습니다
Cal Poly, Team 6-3, Maness Fall 2009 Cal Poly, Team 6-3, Maness Fall 2009 회원
CPSU-MANESS-F09S6G3
5 회원들
안내서 35개 작성하였습니다
댓글 한 개
Does the front casing also have the plastic glass screen on it as well? Or is that separate?
Arthur - 답글
댓글 쓰기
조회 통계:
24 시간 전: 4
7일 전: 56
30일 전: 209
전체 시간: 26,251
