주요 콘텐츠로 건너뛰기
PSP 2000 Speaker Replacement
필요한 것
  1. PSP 2000 Speaker Replacement, Battery: 1 단계, 이미지 3개 중 1개 PSP 2000 Speaker Replacement, Battery: 1 단계, 이미지 3개 중 2개 PSP 2000 Speaker Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place PSP face down, so that the UMD Drive is facing upwards.
    • Locate the battery door and open.
    • Remove the battery from inside.
  2. PSP 2000 Speaker Replacement, Front Casing: 2 단계, 이미지 1개 중 1개
    • This step requires the removal of the warranty sticker. Removing the sticker will void the warranty. According to the FTC removing this will not void your warranty.
    • Locate the sticker in the battery compartment labeled: "En: Warranty Void if Seal Damaged."
    • Remove the sticker using the PSP Opening Tools.
    • Under the sticker is a 5mm Phillips screw needed in the next step.
  3. PSP 2000 Speaker Replacement: 3 단계, 이미지 2개 중 1개 PSP 2000 Speaker Replacement: 3 단계, 이미지 2개 중 2개
    • Remove four 5 mm Phillips from the case.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
  4. PSP 2000 Speaker Replacement: 4 단계, 이미지 2개 중 1개 PSP 2000 Speaker Replacement: 4 단계, 이미지 2개 중 2개
    • Remove the following screws from around the bezel:
    • Two 4 mm Phillips
    • One 5 mm Phillips
    • The two shorter 4 mm screws are on the top of the PSP; the longer 5 mm screw is on the bottom.
  5. PSP 2000 Speaker Replacement: 5 단계, 이미지 2개 중 1개 PSP 2000 Speaker Replacement: 5 단계, 이미지 2개 중 2개
    • Gently pry the front bezel away from the casing using a PSP opening tool.
    • Start on the right hand side of the PSP bezel, and carefully work the tool around the side.
    • If you want to clean the control buttons or D-pad, you can easily pop them out once the faceplate is off and wipe them clean.
  6. PSP 2000 Speaker Replacement, Display: 6 단계, 이미지 3개 중 1개 PSP 2000 Speaker Replacement, Display: 6 단계, 이미지 3개 중 2개 PSP 2000 Speaker Replacement, Display: 6 단계, 이미지 3개 중 3개
    • Remove the home bar by gently prying on the left and right sides of it with the opening tools. Lift the bar out of the device.
    • A ribbon cable connects the home bar to the logic board. Be careful not to damage the cable when removing the bar.
  7. PSP 2000 Speaker Replacement: 7 단계, 이미지 3개 중 1개 PSP 2000 Speaker Replacement: 7 단계, 이미지 3개 중 2개 PSP 2000 Speaker Replacement: 7 단계, 이미지 3개 중 3개
    • With the home bar out of the way, gently pry up the display using the opening tools.
    • There is another ribbon cable attached to the bottom of the LCD. Be careful not to damage either of the connectors when removing.
    • Lift the black tabs of the ribbon cable connectors using a opening tool. Pull the ribbons out towards the bottom of the PSP to disconnect.
    • Gently lift out the display.
  8. PSP 2000 Speaker Replacement, Speaker: 8 단계, 이미지 2개 중 1개 PSP 2000 Speaker Replacement, Speaker: 8 단계, 이미지 2개 중 2개
    • Use the opening tools to press the tab on the left-hand side of the speaker to release it.
    • Be careful not to puncture the speaker in the process.
    • Remove the speaker by twisting it counter-clockwise (to the left, like a screw).
결론
다른 2명이 해당 안내서를 완성하였습니다.
작성자
9다른 기여자 명과 함께
espinks
회원 가입일: 10/18/09
3,761 평판
안내서 5개를 작성함
Cal Poly, Team 6-3, Maness Fall 2009 Cal Poly, Team 6-3, Maness Fall 2009 회원
CPSU-MANESS-F09S6G3
5 회원들
안내서 44개를 작성함
1가이드 댓글
What about the other speaker? How to replace?
felipeavatar - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 22
지난 30일: 100
전체 시간: 14,175
