주요 콘텐츠로 건너뛰기
PSP 300x Front Casing Replacement
필요한 것
  1. PSP 300x Front Casing Replacement, Battery: 1 단계, 이미지 3개 중 1개 PSP 300x Front Casing Replacement, Battery: 1 단계, 이미지 3개 중 2개 PSP 300x Front Casing Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
  2. PSP 300x Front Casing Replacement, Front Casing: 2 단계, 이미지 1개 중 1개
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
  3. PSP 300x Front Casing Replacement: 3 단계, 이미지 2개 중 1개 PSP 300x Front Casing Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
  4. PSP 300x Front Casing Replacement: 4 단계, 이미지 1개 중 1개
    • Next, unscrew the two screws located at the top of the PSP.
  5. PSP 300x Front Casing Replacement: 5 단계, 이미지 1개 중 1개
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
  6. PSP 300x Front Casing Replacement: 6 단계, 이미지 2개 중 1개 PSP 300x Front Casing Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
결론
다른 31명이 해당 안내서를 완성하였습니다.
작성자
16다른 기여자 명과 함께
kbrunner
회원 가입일: 11/05/09
90 평판
안내서 1개를 작성함
Cal Poly, Team 19-2, Maness Fall 2009 Cal Poly, Team 19-2, Maness Fall 2009 회원
CPSU-MANESS-F09S19G2
3 회원들
안내서 12개를 작성함
1가이드 댓글
This is only the faceplate, not a casing replacement, come on
Dick - 답글
댓글 쓰기
조회 통계:
지난 24시간: 5
지난 7일: 42
지난 30일: 220
전체 시간: 21,898
