주요 콘텐츠로 건너뛰기
수리 커뮤니티 가입 - 계정 만들기
PSP 300x Trigger Buttons Replacement
필요한 것
  1. PSP 300x Trigger Buttons Replacement, Battery: 1 단계, 이미지 3개 중 1개 PSP 300x Trigger Buttons Replacement, Battery: 1 단계, 이미지 3개 중 2개 PSP 300x Trigger Buttons Replacement, Battery: 1 단계, 이미지 3개 중 3개
    • Place the PSP face down and locate the battery cover on the left side of the device.
    • Lift and remove the battery cover to reveal the battery.
    • Remove the battery.
    댓글 쓰기
  2. PSP 300x Trigger Buttons Replacement, Front Casing: 2 단계, 이미지 1개 중 1개
    • Peel back the warranty sticker that is behind the battery with a spudger or your fingernail.
    댓글 쓰기
  3. PSP 300x Trigger Buttons Replacement: 3 단계, 이미지 2개 중 1개 PSP 300x Trigger Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Unscrew all four screws from the back of the PSP with the Phillips #00 Screwdriver.
    • Two are located behind the battery's warranty sticker.
    • Two are located on the right side of the PSP.
    댓글 쓰기
  4. PSP 300x Trigger Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Next, unscrew the two screws located at the top of the PSP.
    댓글 쓰기
  5. PSP 300x Trigger Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Then, remove the single screw from the bottom edge of the PSP (which is positioned next to the barcode).
    댓글 쓰기
  6. PSP 300x Trigger Buttons Replacement: 6 단계, 이미지 2개 중 1개 PSP 300x Trigger Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Slide the spudger in between the outer casing of the PSP, beginning at the "R" shoulder button, and gently pry off the casing.
    • Remove the front casing completely.
    댓글 쓰기
  7. PSP 300x Trigger Buttons Replacement, LCD Screen: 7 단계, 이미지 2개 중 1개 PSP 300x Trigger Buttons Replacement, LCD Screen: 7 단계, 이미지 2개 중 2개
    • Push the homebar to the right to release the tab located on the right side of the LCD screen.
    • DO NOT completely remove the homebar, as it is still connected by ribbon cables.
    댓글 쓰기
  8. PSP 300x Trigger Buttons Replacement: 8 단계, 이미지 3개 중 1개 PSP 300x Trigger Buttons Replacement: 8 단계, 이미지 3개 중 2개 PSP 300x Trigger Buttons Replacement: 8 단계, 이미지 3개 중 3개
    • Slowly lift the LCD screen off the PSP starting at the top edge corner.
    • Again, the LCD screen is attached by ribbon cables, so do not remove it completely.
    • Orientation of PSP is flipped in photo.
    댓글 쓰기
  9. PSP 300x Trigger Buttons Replacement: 9 단계, 이미지 2개 중 1개 PSP 300x Trigger Buttons Replacement: 9 단계, 이미지 2개 중 2개
    • Flip the small brown locks on the four ribbon cable connectors up using a spudger or fingernail.
    • Pull all four ribbon cables out.
    • Now remove the LCD screen and homebar from the PSP.
    댓글 쓰기
  10. PSP 300x Trigger Buttons Replacement: 10 단계, 이미지 1개 중 1개
    • Remove the metal tab that lies above the LCD screen.
    • Upon reassembly, make note that the stamped lettering faces down, and the large tab fits just above the motherboard to the right hand side of the left trigger.
    댓글 쓰기
  11. PSP 300x Trigger Buttons Replacement, Trigger Buttons: 11 단계, 이미지 1개 중 1개
    • Remove the screw securing 'L' trigger to the PSP.
    댓글 쓰기
  12. PSP 300x Trigger Buttons Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the white plastic piece that holds the 'L' trigger in place.
    댓글 쓰기
  13. PSP 300x Trigger Buttons Replacement: 13 단계, 이미지 1개 중 1개
    • Remove the 'L' trigger from the PSP.
    댓글 쓰기
  14. PSP 300x Trigger Buttons Replacement: 14 단계, 이미지 1개 중 1개
    • Remove the screw securing the 'R' trigger.
    댓글 쓰기
  15. PSP 300x Trigger Buttons Replacement: 15 단계, 이미지 1개 중 1개
    • Remove the white plastic piece that holds the 'R' trigger in place.
    댓글 쓰기
  16. PSP 300x Trigger Buttons Replacement: 16 단계, 이미지 1개 중 1개
    • Remove the 'R' trigger from the PSP.
    댓글 쓰기
결론
취소: 해당 안내서를 완성하지 않았습니다.
다른 11명이 해당 안내서를 완성하였습니다.
작성자
13다른 기여자 명과 함께
cmcevill
회원 가입일: 11/05/09
541 평판
안내서 1개를 작성함
Cal Poly, Team 19-2, Maness Fall 2009 Cal Poly, Team 19-2, Maness Fall 2009 회원
CPSU-MANESS-F09S19G2
3 회원들
안내서 15개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 4
지난 7일: 37
지난 30일: 215
전체 시간: 24,624
