주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
소개
Make you PSP 3000c like new again by replacing your beat up front case with a shiny new one!
  1. Press the button securing the battery door to the PSP 300xc, and lift the battery door off. Lift the battery out of the PSP.
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. Remove four Phillips screws from the back of the PSP. Remove four Phillips screws from the back of the PSP.
    • Remove four Phillips screws from the back of the PSP.
  4. Remove two Phillips screws from the top of the PSP.
    • Remove two Phillips screws from the top of the PSP.
  5. Remove a single screw from the bottom edge of the PSP.
    • Remove a single screw from the bottom edge of the PSP.
  6. Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it. Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
Matthew Newsom
회원 가입일: 2010년 01월 05일
35,711 평판
안내서 67개 작성하였습니다
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 6
30일 전: 11
전체 시간: 2,354
