주요 콘텐츠로 건너뛰기
기기를 수리하세요
수리할 권리
상점
  1. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Press the button securing the battery door to the PSP 300xc, and lift the battery door off. Lift the battery out of the PSP.
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove four Phillips screws from the back of the PSP. Remove four Phillips screws from the back of the PSP.
    • Remove four Phillips screws from the back of the PSP.
  4. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove two Phillips screws from the top of the PSP.
    • Remove two Phillips screws from the top of the PSP.
  5. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove a single screw from the bottom edge of the PSP.
    • Remove a single screw from the bottom edge of the PSP.
  6. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it. Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove a single Phillips screw securing the home bar to the PSP 300xc.
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly. Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Insert a spudger under the LCD, beside the black plastic tab.
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables. Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors: Home bar cable
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. 이 단계는 번역되지 않았습니다. 번역을 도와주십시오
    Remove the LCD from the PSP 300xc.
    • Remove the LCD from the PSP 300xc.
결승점
다른 10명이 해당 안내서를 완성하였습니다.
Matthew Newsom
회원 가입일: 2010년 01월 05일
36,074 평판
안내서 67개 작성하였습니다
the metal bar on the lcd of the revisioned 3000 is easily removable with a spudger while the first gen 3000s have metal bars like 2000s, repairing any psp 3000 brite units is the easiest one to repair among the 4 other models of psp
Ghost - 답글
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 4
30일 전: 15
전체 시간: 4,181
