주요 콘텐츠로 건너뛰기
PSP 300xc Trigger Buttons Replacement
필요한 것
  1. PSP 300xc Trigger Buttons Replacement, Battery: 1 단계, 이미지 2개 중 1개 PSP 300xc Trigger Buttons Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc Trigger Buttons Replacement, Front Case: 2 단계, 이미지 1개 중 1개
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc Trigger Buttons Replacement: 3 단계, 이미지 2개 중 1개 PSP 300xc Trigger Buttons Replacement: 3 단계, 이미지 2개 중 2개
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc Trigger Buttons Replacement: 4 단계, 이미지 1개 중 1개
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc Trigger Buttons Replacement: 5 단계, 이미지 1개 중 1개
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc Trigger Buttons Replacement: 6 단계, 이미지 2개 중 1개 PSP 300xc Trigger Buttons Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc Trigger Buttons Replacement, LCD: 7 단계, 이미지 1개 중 1개
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc Trigger Buttons Replacement: 8 단계, 이미지 2개 중 1개 PSP 300xc Trigger Buttons Replacement: 8 단계, 이미지 2개 중 2개
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc Trigger Buttons Replacement: 9 단계, 이미지 1개 중 1개
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc Trigger Buttons Replacement: 10 단계, 이미지 1개 중 1개
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc Trigger Buttons Replacement: 11 단계, 이미지 3개 중 1개 PSP 300xc Trigger Buttons Replacement: 11 단계, 이미지 3개 중 2개 PSP 300xc Trigger Buttons Replacement: 11 단계, 이미지 3개 중 3개
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc Trigger Buttons Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc Trigger Buttons Replacement, Home Bar: 13 단계, 이미지 3개 중 1개 PSP 300xc Trigger Buttons Replacement, Home Bar: 13 단계, 이미지 3개 중 2개 PSP 300xc Trigger Buttons Replacement, Home Bar: 13 단계, 이미지 3개 중 3개
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc Trigger Buttons Replacement, Trigger Buttons: 14 단계, 이미지 2개 중 1개 PSP 300xc Trigger Buttons Replacement, Trigger Buttons: 14 단계, 이미지 2개 중 2개
    • Remove both trigger buttons by lifting them off the PSP 300xc.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
3다른 기여자 명과 함께
Matthew Newsom
회원 가입일: 01/05/10
41,975 평판
안내서 67개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 3
지난 7일: 11
지난 30일: 39
전체 시간: 2,918
