주요 콘텐츠로 건너뛰기
PSP 300xc UMD Drive Replacement
필요한 것
  1. PSP 300xc UMD Drive Replacement, Battery: 1 단계, 이미지 2개 중 1개 PSP 300xc UMD Drive Replacement, Battery: 1 단계, 이미지 2개 중 2개
    • Press the button securing the battery door to the PSP 300xc, and lift the battery door off.
    • Lift the battery out of the PSP.
  2. PSP 300xc UMD Drive Replacement, Front Case: 2 단계, 이미지 1개 중 1개
    • Use a spudger or your fingernail to remove the warranty sticker stuck to the inside of the battery tray
  3. PSP 300xc UMD Drive Replacement: 3 단계, 이미지 2개 중 1개 PSP 300xc UMD Drive Replacement: 3 단계, 이미지 2개 중 2개
    • Remove four Phillips screws from the back of the PSP.
  4. PSP 300xc UMD Drive Replacement: 4 단계, 이미지 1개 중 1개
    • Remove two Phillips screws from the top of the PSP.
  5. PSP 300xc UMD Drive Replacement: 5 단계, 이미지 1개 중 1개
    • Remove a single screw from the bottom edge of the PSP.
  6. PSP 300xc UMD Drive Replacement: 6 단계, 이미지 2개 중 1개 PSP 300xc UMD Drive Replacement: 6 단계, 이미지 2개 중 2개
    • Insert a spudger between the front case and PSP, and slide the spudger along the perimeter of the front case to remove it.
  7. PSP 300xc UMD Drive Replacement, LCD: 7 단계, 이미지 1개 중 1개
    • Remove a single Phillips screw securing the home bar to the PSP 300xc.
  8. PSP 300xc UMD Drive Replacement: 8 단계, 이미지 2개 중 1개 PSP 300xc UMD Drive Replacement: 8 단계, 이미지 2개 중 2개
    • Push the home bar to the right about 1cm to release a tab, and begin to lift the right end of the home bar slightly.
    • Do not attempt to remove the home bar yet, it is still attached to the PSP 300xc.
  9. PSP 300xc UMD Drive Replacement: 9 단계, 이미지 1개 중 1개
    • Insert a spudger under the LCD, beside the black plastic tab.
    • Push the LCD to the left and pry up to release the left edge of the LCD from under the plastic tab.
  10. PSP 300xc UMD Drive Replacement: 10 단계, 이미지 1개 중 1개
    • Push the LCD to the right and pry up to release the right edge of the LCD from under the plastic tab.
  11. PSP 300xc UMD Drive Replacement: 11 단계, 이미지 3개 중 1개 PSP 300xc UMD Drive Replacement: 11 단계, 이미지 3개 중 2개 PSP 300xc UMD Drive Replacement: 11 단계, 이미지 3개 중 3개
    • Rotate the LCD away from the PSP to reveal the LCD and home bar ribbon cables.
    • Use your fingernail or the edge of a plastic opening tool to flip up the retaining flap on the following four ZIF connectors:
    • Home bar cable
    • Microphone cable
    • LCD display data cable
    • Touchscreen cable
    • Be sure you are prying up on the retaining flap, not the socket itself
    • After flipping up the locking tabs on all four connectors, use your fingers or a spudger to gently pull the cables straight out of the connectors.
  12. PSP 300xc UMD Drive Replacement: 12 단계, 이미지 1개 중 1개
    • Remove the LCD from the PSP 300xc.
  13. PSP 300xc UMD Drive Replacement, Home Bar: 13 단계, 이미지 3개 중 1개 PSP 300xc UMD Drive Replacement, Home Bar: 13 단계, 이미지 3개 중 2개 PSP 300xc UMD Drive Replacement, Home Bar: 13 단계, 이미지 3개 중 3개
    • Lift the home bar up as high as it will go, but not so high that the wires disconnect.
    • Try to bend the small tab under the silver rim as little as possible it the following steps. The more you bend, the more likely it will snap.
    • Twist the home bar counter clockwise while carefully lifting it further. The left edge has to lift over the black plastic frame to allow it to rotate.
    • The home bar should now lift out of the PSP 300xc.
  14. PSP 300xc UMD Drive Replacement, UMD Brace: 14 단계, 이미지 1개 중 1개
    • Using the flat edge of a spudger, pry the power board away from the PSP 300xc.
  15. PSP 300xc UMD Drive Replacement: 15 단계, 이미지 1개 중 1개
    • Lift the right silver rim up and off the PSP 300xc.
  16. PSP 300xc UMD Drive Replacement: 16 단계, 이미지 1개 중 1개
    • Using the pointed end of a spudger, pull the UMD door spring to the left, and remove it from the PSP.
  17. PSP 300xc UMD Drive Replacement: 17 단계, 이미지 3개 중 1개 PSP 300xc UMD Drive Replacement: 17 단계, 이미지 3개 중 2개 PSP 300xc UMD Drive Replacement: 17 단계, 이미지 3개 중 3개
    • Use your fingernail or the edge of a spudger to flip up the retaining flap on the UMD drive ribbon socket.
    • Use your fingernail or tip of a spudger to push both sides of the black retaining flap on the UMD laser ribbon socket to the right.
    • Use a spudger to gently pull both ribbon cables straight out of their sockets.
  18. PSP 300xc UMD Drive Replacement: 18 단계, 이미지 2개 중 1개 PSP 300xc UMD Drive Replacement: 18 단계, 이미지 2개 중 2개
    이 단계에 사용된 도구:
    • Flip the PSP 300xc over and open the UMD door.
    • Using a pair of tweezers, grab the small rubber square between the metal UMD brace and case, and lift it out of the PSP 300xc.
    • Repeat for the rubber square on the other side of the UMD door.
  19. PSP 300xc UMD Drive Replacement: 19 단계, 이미지 3개 중 1개 PSP 300xc UMD Drive Replacement: 19 단계, 이미지 3개 중 2개 PSP 300xc UMD Drive Replacement: 19 단계, 이미지 3개 중 3개
    • Slide the UMD brace toward the top of the UMD door until the brace disconnects from the door. Remove the brace.
  20. PSP 300xc UMD Drive Replacement, UMD Door: 20 단계, 이미지 2개 중 1개 PSP 300xc UMD Drive Replacement, UMD Door: 20 단계, 이미지 2개 중 2개
    • Bend the PSP 300xc case while pulling up on the right edge of the UMD door until the right edge lifts free.
    • Remove the UMD door.
  21. PSP 300xc UMD Drive Replacement, UMD Drive: 21 단계, 이미지 1개 중 1개
    • Remove the four Phillips screws securing the UMD drive to the PSP 300xc.
  22. PSP 300xc UMD Drive Replacement: 22 단계, 이미지 1개 중 1개
    • Lift the UMD drive out of the PSP 300xc, minding any cables that may get caught.
결론
다른 4명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Matthew Newsom
회원 가입일: 01/05/10
41,972 평판
안내서 67개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 10
지난 30일: 62
전체 시간: 8,883
