주요 콘텐츠로 건너뛰기
PSP E1000 LED Driver Circuit Component Replacement
필요한 것
  1. PSP E1000 LED Driver Circuit Component Replacement, Backlight electronic after water damage: 1 단계, 이미지 1개 중 1개
    • this picture was made after cleaning
  2. PSP E1000 LED Driver Circuit Component Replacement: 2 단계, 이미지 2개 중 1개 PSP E1000 LED Driver Circuit Component Replacement: 2 단계, 이미지 2개 중 2개
    • it took me some time to find the right chip:
    • 1 - TB62752AFUG
    • 2 - Inductor 22µH/0.66A
    • 3 - MSS1P4-M3/89A
    • 4 - 2.2µF / 6,3V
    • 5 - Fuse 0.5A 0603
    • 6 - 1.0µF / 50V
    • 7 - Ferrite bead 30Ohm/3A
결승점
다른 11명이 해당 안내서를 완성하였습니다.
작성자
2다른 기여자 명과 함께
Steven
회원 가입일: 05/06/14
416 평판
안내서 1개를 작성함
7가이드 댓글
Hi Steven,
Thank for your guide. It helped me restore my PSP street (in my case, the fuse was broken). But one more problem is my PSP street has no sound on speaker, but has sound on headphone. Can you give me a glue to fix?
Thank you.
Hoang Binh - 답글
I fixed it! There a broken fuse near the audio ic. Hooray!!!
Hoang Binh -
Hello Hoang Binh, I have the same problem as you, after changing the fuse to illuminate the display, no sound is heard through the speaker (only when connecting headphones, through them). Can you tell me, please, which is the fuse has been changed to solve the sound problem? An image whit the fuse be very helpful.
Olivian -
Hi @olivian. Sorry for late reply. I didn’t take any picture so I cannot point it out exactly. But you can find it yourself. Fuses often have a letter F or FB on it or its color is blue.
Hoang Binh - 답글
댓글 쓰기
조회 통계:
지난 24시간: 1
지난 7일: 23
지난 30일: 148
전체 시간: 12,830
