주요 콘텐츠로 건너뛰기
PSP E1000 Screen black
필요한 것
  1. PSP E1000 Screen black, PSP E1000 Screen black: 1 단계, 이미지 1개 중 1개
    • This is the front and back of the PSP E1000
  2. PSP E1000 Screen black: 2 단계, 이미지 2개 중 1개 PSP E1000 Screen black: 2 단계, 이미지 2개 중 2개
    • Remove all four screws on the back using the same bit as before.
    • Then remove the two top screws.
  3. PSP E1000 Screen black: 3 단계, 이미지 1개 중 1개
    • Insert wisdom here.Gently unclip the display ribbon cable and remove it Then set the display to the side Untape the front panel ribbon cable, unclip it, then remove it.
  4. PSP E1000 Screen black: 4 단계, 이미지 1개 중 1개
    • Remove the ribbon cable and power cable Gently lift the button assembly and charge port The shoulder button is taped down so slide a spudger under the button and gently peel it off
  5. PSP E1000 Screen black: 5 단계, 이미지 1개 중 1개
    • Unclip and remove the two marked ribbon cables Remove the marked screw and lift the analog stick out Lift the button pad carefully and peel off the shoulder button When reassembling install the joystick before the buttons.
  6. PSP E1000 Screen black: 6 단계, 이미지 1개 중 1개
    • Unclip both ribbon cables and remove them Remove the marked screw on the mainboard Lift the bottom of the mainboard up and slide it out For reinstallation make sure that the power switch cover is installed before it is screwed in. It has to be unscrewed to do the installation
  7. PSP E1000 Screen black: 7 단계, 이미지 1개 중 1개
    • Congratulations you have disassembled your PSP E1000. Have fun with the reassembly!
  8. PSP E1000 Screen black: 8 단계, 이미지 1개 중 1개
    • disassemble the console, take a multimeter and measure whether the fuse conducts current, if not, remove the fuse with scissors from a 3D printer or pliers and connect the 2 elements together
  9. PSP E1000 Screen black: 9 단계, 이미지 1개 중 1개
    • here is the fuse
결론
작성자
1다른 기여자 명과 함께
Błażej Stosio
회원 가입일: 05/14/25
169 평판
안내서 1개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 2
지난 7일: 19
지난 30일: 84
전체 시간: 465
