이 버전에는 잘못된 편집 사항이 있을 수 있습니다. 최신 확인된 스냅샷으로 전환하십시오.
필요한 것
이 단계는 번역되지 않았습니다. 번역을 도와주십시오
Unscrew the four Phillips screws on the back of the PSP Go.
Rotate the PSP so you can see the top of the device.
Unscrew the two Phillips screws next to the volume buttons.
Use a plastic opening tool around the perimeter of the back cover to loosen it on all sides.
Open the back cover by gently lifting the right side, and rotating it to the left side (as if you were opening a book).
Remove the two Phillips screws holding the bottom plate.
Gently lift the bottom plate away from the device.
Use a pair of tweezers and grasp the black plastic portion of the headphone jack cable.
Slowly pull out the cable. If it's hard to pull, wiggle it slightly side-to-side while pulling it.
다른 2명이 해당 안내서를 완성하였습니다.
