주요 콘텐츠로 건너뛰기
Pacific Image Electronics CS3600 Bulb Panel Replacement
필요한 것
  1. Pacific Image Electronics CS3600 Bulb Panel Replacement, Bulb Panel: 1 단계, 이미지 2개 중 1개 Pacific Image Electronics CS3600 Bulb Panel Replacement, Bulb Panel: 1 단계, 이미지 2개 중 2개
    • Start by removing the 5 screws that are 5mm x 9mm located on the bottom of the device with a J1 screwdriver.
  2. Pacific Image Electronics CS3600 Bulb Panel Replacement: 2 단계, 이미지 1개 중 1개
    • Now that the screws have been removed, carefully but firmly open up the device at the seam until it is presented as shown.
  3. Pacific Image Electronics CS3600 Bulb Panel Replacement: 3 단계, 이미지 1개 중 1개
    • Use a J0 screwdriver to remove the following four screws that are 5mm x 9mm.
  4. Pacific Image Electronics CS3600 Bulb Panel Replacement: 4 단계, 이미지 1개 중 1개
    • Use the same J0 screwdriver to remove the following 3 screws that are 7mm x 6mm.
  5. Pacific Image Electronics CS3600 Bulb Panel Replacement: 5 단계, 이미지 1개 중 1개
    • Now grab the plastic cover you just removed screws from and gently remove it from the device.
  6. Pacific Image Electronics CS3600 Bulb Panel Replacement: 6 단계, 이미지 1개 중 1개
    • You may now pick up the plastic covering you removed screws from in Step 3 with ease revealing the bulb.
  7. Pacific Image Electronics CS3600 Bulb Panel Replacement: 7 단계, 이미지 1개 중 1개
    • Lodge the plastic opening tool underneath the bulb casing. Using some upward force, pop the bulb off the casing.
  8. Pacific Image Electronics CS3600 Bulb Panel Replacement: 8 단계, 이미지 1개 중 1개
    • You have now removed the bulb from the casing. Gently pull the wires forward and prepare a soldering station.
  9. Pacific Image Electronics CS3600 Bulb Panel Replacement: 9 단계, 이미지 1개 중 1개
    • Carefully desolder the 2 wires from their solder contact points to detach the bulb panel from the motherboard.
결론
다른 한 분이 해당 안내서를 완성하였습니다.
작성자
5다른 기여자 명과 함께
Kristen Prince
회원 가입일: 03/21/17
201 평판
안내서 2개를 작성함
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G2
3 회원들
안내서 10개를 작성함
0가이드 댓글
댓글 쓰기
조회 통계:
지난 24시간: 0
지난 7일: 2
지난 30일: 6
전체 시간: 416
