주요 콘텐츠로 건너뛰기
Pacific Image Electronics CS3600 Button Spring Replacement
필요한 것
  1. Pacific Image Electronics CS3600 Button Spring Replacement, Button Spring: 1 단계, 이미지 1/1
    • Begin opening the device by unscrewing the 5 following 9mm x 7mm screws with a J1 screwdriver.
  2. Pacific Image Electronics CS3600 Button Spring Replacement: 2 단계, 이미지 1/1
    • Once the screws have been removed, with light force open the scanner by pulling it apart at the seam.
  3. Pacific Image Electronics CS3600 Button Spring Replacement: 3 단계, 이미지 1/1
    • With a JIS J0 screwdriver remove the 1 screw that is 7mm x 6mm.
  4. Pacific Image Electronics CS3600 Button Spring Replacement: 4 단계, 이미지 1/1
    • Lift and move the plate with the connected wires out of the way.
  5. Pacific Image Electronics CS3600 Button Spring Replacement: 5 단계, 이미지 1/1
    • Remove the spring and replace it with a new one.
결론
Amber Berry
회원 가입일: 03/21/17
101 평판
안내서 1개 작성함
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 2
30일 전: 9
전체 시간: 169
