주요 콘텐츠로 건너뛰기
Pacific Image Electronics CS3600 Lens Replacement
필요한 것
  1. Pacific Image Electronics CS3600 Lens Replacement, Lens: 1 단계, 이미지 1/2 Pacific Image Electronics CS3600 Lens Replacement, Lens: 1 단계, 이미지 2/2
    • Use the J0 screwdriver to remove the 5 following screws that are 9 mm x 7 mm.
  2. Pacific Image Electronics CS3600 Lens Replacement: 2 단계, 이미지 1/1
    • Using light force open the device by pulling at the seam.
  3. Pacific Image Electronics CS3600 Lens Replacement: 3 단계, 이미지 1/1
    • Use the J0 screwdriver to remove the screws that are 7 mm x 6 mm.
  4. Pacific Image Electronics CS3600 Lens Replacement: 4 단계, 이미지 1/1
    • Once the screws are removed and casing removed the lens is revealed.
  5. Pacific Image Electronics CS3600 Lens Replacement: 5 단계, 이미지 1/1
    • Simply remove the lens and replace accordingly!
결론
Kristen Prince
회원 가입일: 03/21/17
201 평판
안내서 2개 작성하였습니다
Texas Tech, Team S46-G2, Bennett Spring 2017 Texas Tech, Team S46-G2, Bennett Spring 2017 회원
TTU-BENNETT-S17S46G2
3 회원들
안내서 10개 작성하였습니다
댓글 0개
댓글 쓰기
조회 통계:
24 시간 전: 0
7일 전: 5
30일 전: 14
전체 시간: 213
